0004369 | ParaView | (No Category) | public | 2007-01-25 19:44 | 2009-12-09 14:51 | ||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0004369: SNL: File read locations not saved - 2.6 | ||||||||
Description | * ParaView is not saving file read location between reads. - Run ParaView 2.6. - File/Open Data. It will show wherever you ran ParaView from. - Go to your data directory, open some data. - Delete all modules, or exit ParaView. - Run ParaView (if necessary), - File/Open Data. It will show wherever you ran ParaView from, now where your last load was located.. | ||||||||
(0006270) Amy Squillacote (reporter) 2007-01-26 08:07 |
This has been corrected on the 2.6 branch. See revision 1.800.2.3 of vtkPVWindow.cxx |
