0004390 | ParaView | (No Category) | public | 2007-02-01 12:37 | 2009-12-09 14:49 | ||||
Reporter | Mattijs Janssens | ||||||||
Assigned To | |||||||||
Summary | 0004390: build with relative paths fails compiling hdf | ||||||||
Description | Switch on relative paths: CMAKE_USE_RELATIVE_PATHS:BOOL=OFF Compilation fails at hdf: make[2]: Entering directory `/home/hunt2/mattijs/OpenFOAM/linuxSrc/ParaView-2.6.0/platforms/linuxAMD64Gcc4Opt' Building C object Utilities/hdf5/CMakeFiles/H5detect.dir/H5detect.o /home/hunt2/mattijs/OpenFOAM/linuxAMD64/gcc-4.1.1/bin/gcc -m64 -fPIC -I../../../../Utilities/hdf5 -I../.. -I../../VTK/Utilities -I. -I../../../../VTK/Utilities -I../../../../VTK -I../../VTK -DVTK_PYTHON_BUILD -DMPICH_IGNORE_CXX_SEEK -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -D_LARGEFILE_SOURCE -o Utilities/hdf5/CMakeFiles/H5detect.dir/H5detect.o -c ../../Utilities/hdf5/H5detect.c In file included from ../../Utilities/hdf5/H5private.h:28, from ../../Utilities/hdf5/H5detect.c:55: ../../Utilities/hdf5/H5public.h:33:72: error: H5pubconf.h: No such file or directory | ||||||||
(0006331) Sylvain Jaume (reporter) 2007-02-02 11:58 |
CMAKE_USE_RELATIVE_PATHS:BOOL=ON is not supported. No immediate plan to fix it. Andy and I checked that this option didn't work with the old HDF5 library (prior to Jan 1, 2007) either. |
2007-08-05 13:49 | Berk Geveci | Assigned To | David Karelitz => |
2007-08-05 13:49 | Berk Geveci | Priority | urgent => normal |
2007-08-05 13:49 | Berk Geveci | Status | @80@ => closed |
2007-08-05 13:49 | Berk Geveci | Resolution | won't fix => fixed |
2007-08-05 13:50 | Berk Geveci | Summary | Goodsite => build with relative paths fails compiling hdf |
2007-08-05 13:50 | Berk Geveci | Note Deleted: 0008170 | |
2007-08-05 13:50 | Berk Geveci | Project | @19@ => @3@ |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
