0004391 | ParaView | (No Category) | public | 2007-02-01 15:16 | 2009-12-09 14:51 | ||||
Priority | urgent | Severity | major | Reproducibility | always | ||||
Summary | 0004391: SNL: 2.6: Fatal crash: servers bad X server connection. | ||||||||
Description | When running ParaView 2.6, Client/Server on a server that doesn't have a grapics card, I get the following error: Process id: 0 >> ERROR: In /projects/viz/paraview/src/ParaView/2.6/ParaView/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 497 vtkXOpenGLRenderWindow (0xcec7e00): bad X server connection. DISPLAY=:0 Process id: 0 >> ERROR: In /projects/viz/paraview/src/ParaView/2.6/ParaView/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 319 vtkXOpenGLRenderWindow (0xcec7e00): bad X server connection. DISPLAY=:0 This is probably the same error as reported on an e-mail listed as PV2.6 Crashes. I am including that e-mail here: I'm using the released PV2.6 and seeing some strange crashes. I'm using the Windows Version you guys compiled for the pvclient, and running the PVServer on a linux Cluster. I compiled the server myself with OSMesa ( 6.4.2) & MPI (OpenMPI 1.1.1-1)support, and i'm running it on multiple processors (the number doesn't matter). When I compiled it, I seeded CMake with the following cache: BUILD_DOCUMENTATION:BOOL=OFF BUILD_EXAMPLES:BOOL=OFF BUILD_SHARED_LIBS:BOOL=ON BUILD_TESTING:BOOL=OFF CMAKE_BUILD_TYPE:STRING=Release CMAKE_CXX_COMPILER:FILEPATH=/usr/local/ofed/mpi/gcc/openmpi-1.1.1-1/bin/mpicxx CMAKE_C_COMPILER:FILEPATH=/usr/local/ofed/mpi/gcc/openmpi-1.1.1-1/bin/mpicc CMAKE_INSTALL_PREFIX:PATH=/viz/home/rhand/local/pv-2.4 //Path to a file. MPI_INCLUDE_PATH:PATH=/usr/local/ofed/mpi/gcc/openmpi-1.1.1-1 /include MPI_LIBRARY:FILEPATH=/usr/local/ofed/mpi/gcc/openmpi-1.1.1-1/lib64/libmpi.so OPENGL_INCLUDE_DIR:PATH=/viz/home/rhand/local/include OPENGL_gl_LIBRARY:FILEPATH=/viz/home/rhand/local/lib/libVTKMesaGL.so OPENGL_glu_LIBRARY:FILEPATH=/viz/home/rhand/local/lib/libVTKMesaGLU.so OPENGL_xmesa_INCLUDE_DIR:PATH=/viz/home/rhand/local/include OSMESA_INCLUDE_DIR:PATH=/viz/home/rhand/local/include OSMESA_LIBRARY:FILEPATH=/viz/home/rhand/local/lib/libOSVTKMesa.so VTK_OPENGL_HAS_OSMESA:BOOL=ON VTK_USE_64BIT_IDS:BOOL=ON VTK_USE_MPI:BOOL=ON VTK_USE_RPATH:BOOL=OFF Problem #1: If I load an ImageData dataset (VTI) and then attempt to use the Clip filter on it, it crashes every time. Also, I get no ghost cells so when I extract an isosurface the process boundaries are clearly visible. I place the Clip Filter at roughly 45-degrees (eyeballed, not much precision) so that it gives me the lower-left half of the data, and when it crashes I get a trace like the following: Connected to client Process id: 0 >> ERROR: In /viz/home/rhand/src/pv- 2.6/comp/PV/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 497 vtkXOpenGLRenderWindow (0x5362f50): bad X server connection. DISPLAY=Process id: 0 >> ERROR: In /viz/home/rhand/src/pv- 2.6/comp/PV/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 319 Signal:11 info.si_errno:0(Success) si_code:1(SEGV_MAPERR) Failing at addr:0x10 [0] func:/usr/local/ofed/mpi/gcc/openmpi-1.1.1-1/lib64/libopal.so.0 [0x2a9bf15dd5] [1] func:/lib64/tls/libpthread.so.0 [0x3dd910c430] [2] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN22vtkXOpenGLRenderWindow13CreateAWindowEv+0x216) [0x2a984e13f6] [3] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN22vtkXOpenGLRenderWindow16WindowInitializeEv+0x12) [0x2a984e21d2] [4] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN22vtkXOpenGLRenderWindow5StartEv+0xd) [0x2a984e249d] [5] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN15vtkRenderWindow14DoStereoRenderEv+0x10) [0x2a98452160] [6] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN15vtkRenderWindow10DoFDRenderEv+0x36b) [0x2a984520fb] [7] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN15vtkRenderWindow10DoAARenderEv+0x46b) [0x2a98451d3b] [8] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN15vtkRenderWindow6RenderEv+0x149) [0x2a98451439] [9] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN22vtkXOpenGLRenderWindow6RenderEv+0x1c) [0x2a984e437c] [10] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN25vtkOpenGLExtensionManager20ReadOpenGLExtensionsEv+0xc0) [0x2a984ab450] [11] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkRendering.so.pv2.6(_ZN25vtkOpenGLExtensionManager6UpdateEv+0x52) [0x2a984aac12] [12] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN32vtkPVOpenGLExtensionsInformation14CopyFromObjectEP9vtkObject+0xf9) [0x2a955b0bf9] [13] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN17vtkSelfConnection17GatherInformationEjP16vtkPVInformation17vtkClientServerID+0x83) [0x2a955dc163] [14] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN20vtkMPISelfConnection17GatherInformationEjP16vtkPVInformation17vtkClientServerID+0x64) [0x2a9559e684] [15] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN19vtkClientConnection15SendInformationER21vtkClientServerStream+0x1d5) [0x2a9558ff65] [16] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_Z39vtkClientConnectionGatherInformationRMIPvS_ii+0x48) [0x2a955900b8] [17] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkParallel.so.pv2.6(_ZN25vtkMultiProcessController10ProcessRMIEiPvii+0x9e) [0x2a9707ef6e] [18] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkParallel.so.pv2.6(_ZN25vtkMultiProcessController11ProcessRMIsEii+0xa0) [0x2a9707f3b0] [19] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN19vtkRemoteConnection20ProcessCommunicationEv+0x14) [0x2a955d9fb4] [20] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN33vtkProcessModuleConnectionManager18MonitorConnectionsEm+0x2d9) [0x2a955d81d9] [21] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN16vtkProcessModule11StartServerEm+0x76) [0x2a955cb676] [22] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVServerCommon.so(_ZN16vtkProcessModule5StartEiPPc+0x24d) [0x2a955ce8cd] [23] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/libvtkPVFilters.so(_ZN9vtkPVMain3RunEP12vtkPVOptions+0x7b) [0x2a95857b7b] [24] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/pvserver-real(main+0xc2) [0x402482] [25] func:/lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x3dd881c3fb] [26] func:/viz/home/rhand/local/pv2.6/lib/paraview-2.6/pvserver-real(__gxx_personality_v0+0x5a) [0x40232a] *** End of error message *** If I load the same ImageData Dataset & apply the D3 filter, then attempt to use the Clip filter, it works. I have alot of rendering artifacts (I think due to the Structured->Unstructured conversion) and it takes ALOT of memory, but it works. | ||||||||
(0006311) Alan Scott (manager) 2007-02-01 15:20 |
Dumby me, I should have mentioned how to create this bug. Run ParaView 2.6, client/server. Linux. The server needs to not have a display, so that DISPLAY:0 is bad. Open can.exo. The server will die. Alan |
(0006352) Berk Geveci (administrator) 2007-02-05 13:52 |
revision 1.1.8.1 date: 2007-02-05 18:49:41 +0000; author: berk; state: Exp; lines: +16 -2 BUG: Server should not create a window when rendering offscreen with Mesa |
(0006356) Alan Scott (manager) 2007-02-05 16:54 |
Works on Liberty and spirit. Alan |
