0004405 | ParaView | (No Category) | public | 2007-02-05 15:38 | 2007-02-12 17:47 | ||||
Summary | 0004405: Animation properties do not match object inspector | ||||||||
Description | When selecting the property to animate in the Animation Inspector, the names in the chooser box do not match those in the Object Inspector. For example, I was just setting up a toy animation where I animated the maximum number of steps taken in the stream tracer. In the Object Inspector, the field is called "Max. Steps" whereas in the Animation Inspector it is called "MaximumNumberOfSteps". It should be listed as "Max. Steps" in both places. | ||||||||
(0006405) Utkarsh Ayachit (administrator) 2007-02-12 16:05 |
The Animation Panel now uses ServerManager labels specified in the XML. |
