0004412 | ParaView | (No Category) | public | 2007-02-05 19:50 | 2007-02-22 15:02 | ||||
Summary | 0004412: No. Frames/Duration parameter ignored | ||||||||
Description | In the "Scene Properties" of the Animation Inspector, the value that controls the length of the animation ("No. Of Frames" for Sequence and "Duration" for Play Mode) seems to have no effect. It always uses the value "10" for this parameter (10 frames in sequence and 10 seconds in real time). | ||||||||
(0006362) Utkarsh Ayachit (administrator) 2007-02-06 09:37 |
NumberOfFrames and Duration were erroneously not marked update_self. Consequently, the commands were never called on the proxy. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.79; previous revision: 1.78 |
(0006530) Ken Moreland (manager) 2007-02-21 18:56 |
This is broken again. I can generate the right amount of frames when in Sequence mode, but in Real Time mode it always seems to revert to saving the number of frames set the last time it was in Sequence mode. |
(0006536) Utkarsh Ayachit (administrator) 2007-02-22 10:09 |
While saving animations, the animation is never actually saved in real-time mode. It always switches to Sequence mode, however, we are expected to have updated the sequence num-of-frames and frame rate so that the user selection for the time for the animation is preserved. The bug was that the animation manager did not change the sequence play-back parameter as it should. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.cxx,v <-- pqAnimationManager.cxx new revision: 1.12; previous revision: 1.11 |
