0004432 | ParaView | (No Category) | public | 2007-02-08 15:23 | 2007-04-02 16:35 | ||||
Reporter | Eric Stanton | ||||||||
Assigned To | Eric Stanton | ||||||||
Priority | normal | Severity | major | Reproducibility | unable to reproduce | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0004432: Load State: Threshold filter parameters not being restored | ||||||||
Description | When a state is loaded that includes a threshold filter, the variable being thresholded does not show up in the list of possible ones and the range of values is incorrect. | ||||||||
(0006679) Eric Stanton (reporter) 2007-03-07 23:39 |
I've added a dependency to bug 0004472 where a reader's properties are not getting restored correctly. Thresholding in a state script does work correctly when thresholding by a variable that does not have to be turned on explicitly in the reader (i.e. global node id). |
(0006773) Berk Geveci (administrator) 2007-03-13 15:28 |
Is this fixed now that Exodus state loading bug is fixed? |
(0006777) Eric Stanton (reporter) 2007-03-13 15:39 |
Not exactly. When you load state/lookmark with a threshold filter in it, the view initially is correct. But when you click on the threshold filter in the pipeline browser, it seems to revert to some default values for the selected variable array and threshold range. I'll look into it. |
(0007024) Eric Stanton (reporter) 2007-03-30 16:39 |
Looks like the bug fairies fixed this for me! |
