0004447 | ParaView | (No Category) | public | 2007-02-12 17:23 | 2007-09-10 12:40 | ||||
Summary | 0004447: Time interpolator filter | ||||||||
Description | We should have a filter that interpolates its input over time. Basically, it asks its source for the two nearest time steps and then does a linear interpolation (at least on the first pass). To make the problem tractable, let's assume that the geometry of the input does not change. | ||||||||
(0006923) Ken Moreland (manager) 2007-03-23 13:06 |
There is now a temporal interpolator in ParaView. It works pretty well on exodus data, but there have been problems with multiblock data. We may want to hide it in the 3.0 release until things stabilize. |
(0007067) Ken Moreland (manager) 2007-04-02 16:48 |
Since this has been "hidden" in PV 3.0, I am going to reopen this bug with a low priority to remind us to re-enable this in PV 3.2. |
(0008483) Ken Moreland (manager) 2007-08-16 08:16 |
Checked in changes to add the temporal interpolator as well as the cache and shift scale. I also added some tests for the interpolator and shift scale. /cvsroot/ParaView3/ParaViewData/Baseline/TemporalInterpolator.png,v <-- TemporalInterpolator.png initial revision: 1.1 /cvsroot/ParaView3/ParaViewData/Baseline/TemporalShiftScale.png,v <-- TemporalShiftScale.png initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Applications/Client/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.153; previous revision: 1.152 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/TemporalInterpolator.xml,v <-- TemporalInterpolator.xml initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Applications/Client/Testing/XML/TemporalShiftScale.xml,v <-- TemporalShiftScale.xml initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewFilters.xml,v <-- ParaViewFilters.xml new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.250; previous revision: 1.249 |
2007-08-16 08:05 | Ken Moreland | Priority | low => high |
2007-08-16 08:05 | Ken Moreland | Status | backlog => tabled |
2007-08-16 08:16 | Ken Moreland | Status | tabled => @80@ |
2007-08-16 08:16 | Ken Moreland | Resolution | reopened => fixed |
2007-08-16 08:16 | Ken Moreland | Note Added: 0008483 | |
2007-09-10 12:40 | Ken Moreland | Status | @80@ => closed |
