0004468 | ParaView | (No Category) | public | 2007-02-15 16:44 | 2007-03-12 11:56 | ||||
Summary | 0004468: Cannot animate clip planes | ||||||||
Description | There is no way to animate the implicit plane in the Clip filter (and similar). | ||||||||
(0006607) Utkarsh Ayachit (administrator) 2007-03-01 11:17 |
Added support to animate properties from proxies not directly seen in the pipeline browser such as clip planes etc. It relies on the fact that for such proxy properties there exists a vtkSMProxyListDomain. /cvsroot/ParaView3/ParaView3/Qt/Core/pqAnimationScene.cxx,v <-- pqAnimationScene.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProxy.cxx,v <-- pqProxy.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Core/pqProxy.h,v <-- pqProxy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.cxx,v <-- pqAnimationPanel.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.h,v <-- pqAnimationPanel.h new revision: 1.4; previous revision: 1.3 |
(0006654) Ken Moreland (manager) 2007-03-06 12:32 |
There is something not quite right. I can animate the X value for the cut-plane normal just fine, but when I try to animate the Y or Z values, they get set to zero no matter what values I set in the animation inspector. |
(0006664) Utkarsh Ayachit (administrator) 2007-03-06 20:00 |
Wrong index was used while connecting the key value widget to the KeyValues property. Hence it used to work only for 0th index. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationPanel.cxx,v <-- pqAnimationPanel.cxx new revision: 1.20; previous revision: 1.19 |
