0004648 | ParaView | (No Category) | public | 2007-03-21 15:32 | 2009-05-13 13:47 | ||||
Reporter | Eric Stanton | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0004648: Widgets used in a custom filter's object panel do not match those in the original filter | ||||||||
Description | In the contour filter, for example, the Isosurfaces values are entered differently in the contour filter panel than they are in a custom filter made up of a custom filter with the Isosurfaces property exposed. | ||||||||
(0007280) Berk Geveci (administrator) 2007-04-13 09:38 |
I believe this is fixed. Am I wrong? |
(0007297) Eric Stanton (reporter) 2007-04-13 14:11 |
No, this is still an issue. Though we should ask Ken how critical it is since he originally reported it. |
(0014950) Ken Moreland (manager) 2009-02-16 14:57 |
This should only be an issue when dealing with filters that have custom panels (otherwise the GUI should match). The way around that is to change the filter back to autogenerated by adding things like hints and domains to suggest how to build the GUI. These have to be dealt with on a case-by-case basis and each should have their own bug. |
(0014985) Alan Scott (manager) 2009-02-16 18:31 |
Closed. See Ken's note above. |
2007-11-30 14:16 | Utkarsh Ayachit | Assigned To | Eric Stanton => Utkarsh Ayachit |
2008-04-08 16:19 | Berk Geveci | Category | => 3.6 |
2008-04-08 16:19 | Berk Geveci | Assigned To | Utkarsh Ayachit => Clinton Stimpson |
2009-02-16 14:57 | Ken Moreland | Note Added: 0014950 | |
2009-02-16 14:57 | Ken Moreland | Status | tabled => @80@ |
2009-02-16 14:57 | Ken Moreland | Resolution | open => won't fix |
2009-02-16 18:31 | Alan Scott | Note Added: 0014985 | |
2009-02-16 18:31 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
