0004663 | ParaView | (No Category) | public | 2007-03-23 09:07 | 2009-12-09 21:45 | ||||
Reporter | Ronald Rook | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0004663: Plane widget bug | ||||||||
Description | Cutting plane does not (automatically) snap to a unit cube input data. * Cube source (set center point to 0.5,0.5,0,5) * Cut Filter | ||||||||
Attached Files | paraview-cut-bug.png [^] (56,806 bytes) 1969-12-31 19:00
(0006926) Ken Moreland (manager) 2007-03-23 14:34 |
Wow. That's weird. It appears to only happen if the bounds of the object are [0,1] on all axis. If you changed the center or any length of the box in any way, the bounds of the plane widget work again. My guess is that the bounds (0,1,0,1,0,1) have some special meaning to the 3D plane widget. Or maybe the default value of some server manager property is set to (0,1,0,1,0,1) when it should default to (-0.5,0.5,-0.5,0.5,-0.5,0.5). Whatever the problem is, it doesn't seem to occur in ParaView 3. |
2009-12-09 21:45 | Berk Geveci | Status | tabled => closed |
2009-12-09 21:45 | Berk Geveci | Resolution | open => fixed |
