0004679 | ParaView | (No Category) | public | 2007-03-26 12:53 | 2007-09-11 17:44 | ||||
Reporter | David Karelitz | ||||||||
Assigned To | Eric Stanton | ||||||||
Summary | 0004679: Cannot create folder in Save State dialog when running client/Server | ||||||||
Description | The create new folder icon is greyed out when running client/server and trying to save state. Is it possible to enable this functionality? | ||||||||
(0006949) David Karelitz (reporter) 2007-03-27 10:59 |
Save Animation has the same problem |
(0007050) Eric Stanton (reporter) 2007-04-02 12:47 |
You weren't able to do this in standalone mode either. You can now. But I'm still working on a fix for client/server. |
(0007262) David Karelitz (reporter) 2007-04-12 16:41 |
This still doesn't work client/server when trying to save server state (new folder button is greyed out). |
(0008346) Clinton Stimpson (developer) 2007-08-06 19:09 |
I'd suggest doing it like QFileDialog does it. Actually create a "New Folder" directory, make it editable, then support a rename. We'd need to add file/folder rename functions in pqFileDialogModel. |
(0008768) Eric Stanton (reporter) 2007-08-29 19:01 |
Since you can only load state scripts from the client filesystem, maybe we just shouldn't allow the user to save them to the server? |
(0008769) Eric Stanton (reporter) 2007-08-29 19:02 |
nevermind, forget my last comment...its the end of the day :). |
(0008845) Ken Moreland (manager) 2007-09-05 16:31 |
Very strange. When I try to create a directory when saving a state file in client/server mode, it locks up my entire computer. |
(0008851) Eric Stanton (reporter) 2007-09-05 17:37 |
Wow that's not good. What platform was your client running on? |
(0008852) Ken Moreland (manager) 2007-09-05 17:39 |
Windows XP. |
(0008853) Eric Stanton (reporter) 2007-09-05 22:52 |
After several tries, I haven't been able to reproduce this. Does it freeze for you after you press the create folder button, after the line edit is displayed and you press <Return> to create the folder, or both? |
(0008860) Ken Moreland (manager) 2007-09-06 13:50 |
It happens as soon as I hit the create directory button. |
(0008931) Eric Stanton (reporter) 2007-09-11 17:14 |
Ken, could you try this out and let me know if its still hanging for you? |
(0008933) Ken Moreland (manager) 2007-09-11 17:44 |
Yup. It's working for me now. |
2007-08-06 19:09 | Clinton Stimpson | Note Added: 0008346 | |
2007-08-29 19:01 | Eric Stanton | Note Added: 0008768 | |
2007-08-29 19:02 | Eric Stanton | Note Added: 0008769 | |
2007-08-30 14:03 | Eric Stanton | Status | backlog => @80@ |
2007-08-30 14:03 | Eric Stanton | Resolution | reopened => fixed |
2007-09-05 16:31 | Ken Moreland | Status | @80@ => @20@ |
2007-09-05 16:31 | Ken Moreland | Resolution | fixed => reopened |
2007-09-05 16:31 | Ken Moreland | Note Added: 0008845 | |
2007-09-05 17:37 | Eric Stanton | Note Added: 0008851 | |
2007-09-05 17:39 | Ken Moreland | Note Added: 0008852 | |
2007-09-05 22:52 | Eric Stanton | Note Added: 0008853 | |
2007-09-06 13:50 | Ken Moreland | Note Added: 0008860 | |
2007-09-11 17:14 | Eric Stanton | Status | @20@ => @80@ |
2007-09-11 17:14 | Eric Stanton | Resolution | reopened => fixed |
2007-09-11 17:14 | Eric Stanton | Note Added: 0008931 | |
2007-09-11 17:44 | Ken Moreland | Status | @80@ => closed |
2007-09-11 17:44 | Ken Moreland | Note Added: 0008933 | |
