0004733 | ParaView | (No Category) | public | 2007-03-30 16:53 | 2007-04-03 14:59 | ||||
Reporter | David Karelitz | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0004733: Selection on exodus files with Node and Side sets | ||||||||
Description | If you open an exodus file containing node and side sets, disable all the blocks, and enable all the sets; selection selects random points from the node set. | ||||||||
(0007026) Clinton Stimpson (developer) 2007-03-30 23:42 |
Mind taking this one Dave? |
(0007039) user521 2007-04-01 19:19 |
I updated the vtkIdentColoredPainter to render the VERTEX cells when it does the selection render passes. This keeps the vtkOriginalCellIds array lined up when node sets are turned on/off. I believe the side sets are working too now. I turned them on and selected and the selection looked correct. |
