0004735 | ParaView | (No Category) | public | 2007-03-30 16:56 | 2007-04-03 14:49 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0004735: Enabling exodus variable after first accept causes it not to show up on display tab | ||||||||
Description | If you open an exodus file and enable additional variables after the first accept, they don't show up on the Display tab until you go to a different filter/source and back to the exodus reader. They do show up in the color by toolbar. | ||||||||
(0007031) Utkarsh Ayachit (administrator) 2007-03-31 13:59 |
ENH: Displays now fire an event, vtkSMAbstractDisplayProxy::ForceUpdatedEvent whenever the display is updated i.e. Update() is called on the display. BUG: Fixes BUG# 4735. pqDisplayColorWidget does not rely on any one to notify the widget that "accept" was called and it should reload it's arrays as they might have changed. Instead, it uses the new ForceUpdatedEvent from the display itself to know that arrays may have changed. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.cxx,v <-- pqDisplayColorWidget.cxxnew revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.h,v <-- pqDisplayColorWidget.h new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.156; previous revision: 1.155 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplay.cxx,v <-- pqDisplay.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplay.h,v <-- pqDisplay.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMAbstractDisplayProxy.h,v <-- vtkSMAbstractDisplayProxy.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCubeAxesDisplayProxy.cxx,v <-- vtkSMCubeAxesDisplayProxy.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataObjectDisplayProxy.cxx,v <-- vtkSMDataObjectDisplayProxy.cxx new revision: 1.37; previous revision: 1.36 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMGenericViewDisplayProxy.cxx,v <-- vtkSMGenericViewDisplayProxy.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPointLabelDisplayProxy.cxx,v <-- vtkSMPointLabelDisplayProxy.cxx new revision: 1.19; previous revision: 1.18 |
