0004770 | ParaView | (No Category) | public | 2007-04-02 19:01 | 2007-04-03 18:01 | ||||
Summary | 0004770: Opacity parameter not working | ||||||||
Description | The opacity rendering parameter, set under "Style" in the Display panel, is not working. Opacity of 1.0 correctly shows opaque and 0.0 correctly shows nothing, but anything in between also shows completely opaque. If you run on a machine that does not support depth peeling, you can tell that the z-buffer has been turned off, but the colors are not properly blended. | ||||||||
(0007093) Berk Geveci (administrator) 2007-04-03 09:52 |
We should enable depth peeling too. |
(0007095) Utkarsh Ayachit (administrator) 2007-04-03 10:29 |
Alpha was not passed to internal LUT. consequently color mapping didn't use vtkProperty alpha while rendering. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVLookupTable.cxx,v <-- vtkPVLookupTable.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVLookupTable.h,v <-- vtkPVLookupTable.h new revision: 1.6; previous revision: 1.5 |
(0007096) Utkarsh Ayachit (administrator) 2007-04-03 10:29 |
Depth peeling is already enabled. |
