0004780 | ParaView | (No Category) | public | 2007-04-03 17:41 | 2007-04-09 12:33 | ||||
Summary | 0004780: Editing scalar value does not update tf widget | ||||||||
Description | In the "Color Scale Editor" dialog box, when you type a value in the "Scalar Value" line edit, the change does not effect the transfer function widget right above it until you click on the transfer function widget. This is really annoying because I will change the scalar value of a control point then go back and click on the control point. However, the control point changed without showing it, so when I click, the control point I meant to click on suddenly moves and a new control point that I did not want is created. | ||||||||
(0007139) Mark Richardson (reporter) 2007-04-04 14:56 |
I added a tf render which seems to fix this problem. Let me know if you still see it. |
