0004781 | ParaView | (No Category) | public | 2007-04-03 17:46 | 2007-04-05 13:10 | ||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0004781: Setting scalar value causes control point to move to bottom | ||||||||
Description | In the "Color Scale Editor" when editing colors for surfaces, the control points in the transfer function editor are all constrained to be on a line in the vertical middle of the widget. However, if you change the "Scalar Value" of one of the control points with the corresponding line edit, the control point moves to the bottom of the transfer function widget. I've attached a screen shot showing that. If you grab the point and drag it, it snaps back to the middle of the transfer function widget. | ||||||||
Attached Files | BadControlPointPlacement.png [^] (18,766 bytes) 1969-12-31 19:00
(0007140) Mark Richardson (reporter) 2007-04-04 14:57 |
I added a tf render after the line edit change that fixes the problem. |
(0007160) Mark Richardson (reporter) 2007-04-05 12:20 |
This bug is happening again after the recent changes to the tfe. I believe everything is still correct in the dialog code. The call to render is still there. However, editing the scalar value of a point makes it drop to the bottom. Rescaling the range fixes the line. |
(0007164) Amy Squillacote (reporter) 2007-04-05 13:10 |
This has now been fixed. I'm not sure how it ever worked. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTransferFunctionEditorWidgetSimp le1D.cxx,v <-- vtkTransferFunctionEditorWidgetSimple1D.cxx new revision: 1.26; previous revision: 1.25 |
