0004782 | ParaView | (No Category) | public | 2007-04-03 19:32 | 2007-04-09 12:41 | ||||
Summary | 0004782: Plane widget does not work with compositing | ||||||||
Description | The transparent polygon in the 3D plane widget is causing problems with parallel image compositing. The attached screen capture movie demonstrates the problems. | ||||||||
Attached Files | ParaView_plane_composite_bug.wmv [^] (851,377 bytes) 1969-12-31 19:00 | ||||||||
(0007156) Utkarsh Ayachit (administrator) 2007-04-05 10:28 |
Plane wiget was using transparency which cause compositing woes. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMImplicitPlaneRepresentationProxy.cxx,v <-- vtkSMImplicitPlaneRepresentationProxy.cxx |
