0004786 | ParaView | (No Category) | public | 2007-04-03 20:44 | 2011-01-13 17:00 | ||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0004786: Reflect filter does not work in parallel | ||||||||
Description | If you are using the refelct filter in parallel using one of the min/max planes, it fails. Each process performs a reflection on the local min or max. | ||||||||
Relationships | |||||||||||
(0012141) Ken Moreland (manager) 2008-05-28 10:26 |
Nathan has written a reflect filter that works with both composite data and in parallel. It is currently checked into vtkSNL. |
(0012668) Utkarsh Ayachit (administrator) 2008-07-09 09:16 |
vtkReflectionFilter now support composite datasets. Added new vtkPReflectionFilter which support reflection in parallel. /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkPReflectionFilter.cxx,v <-- VTK/Parallel/vtkPReflectionFilter.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkPReflectionFilter.h,v <-- VTK/Parallel/vtkPReflectionFilter.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Parallel/CMakeLists.txt,v <-- VTK/Parallel/CMakeLists.txt new revision: 1.167; previous revision: 1.166 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.300; previous revision: 1.299 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkReflectionFilter.cxx,v <-- VTK/Graphics/vtkReflectionFilter.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkReflectionFilter.h,v <-- VTK/Graphics/vtkReflectionFilter.h new revision: 1.8; previous revision: 1.7 |
(0012728) Alan Scott (manager) 2008-07-16 22:25 |
Tested client/server, 6 servers. Used can.exo, then d3, then reflect. Works fine. |
2008-04-09 11:57 | Berk Geveci | Category | => 3.6 |
2008-04-15 17:39 | Ken Moreland | Relationship added | related to 0006812 |
2008-04-15 17:41 | Ken Moreland | Category | 3.6 => 3.4 |
2008-04-15 17:41 | Ken Moreland | Relationship added | child of 0006213 |
2008-05-28 10:26 | Ken Moreland | Note Added: 0012141 | |
2008-06-03 11:37 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-07-09 09:16 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-07-09 09:16 | Utkarsh Ayachit | Resolution | open => fixed |
2008-07-09 09:16 | Utkarsh Ayachit | Note Added: 0012668 | |
2008-07-16 22:25 | Alan Scott | Status | @80@ => closed |
2008-07-16 22:25 | Alan Scott | Note Added: 0012728 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
