0004788 | ParaView | (No Category) | public | 2007-04-04 10:54 | 2009-05-13 13:59 | ||||
Priority | low | Severity | feature | Reproducibility | always | ||||
Status | closed | Resolution | duplicate | ||||||
Summary | 0004788: Texture mapping | ||||||||
Description | ParaView 2.6 supported texture mapping. We should supported in ParaView 3. To add texture mapping, we need the following: 1. Add an entry to the Display panel under "Style" for Texture. The associated combo box should work like the Material where the user can select a previously loaded texture or load a new one from an image file. 2. Add the TextureMapToCylinder, TextureMapToPlane, and TextureMapToSphere filters to the lists of filters in ParaViewFilters.xml. 3. Add the ability to compute texture coordinates in the array calculator. Alternatively (or in addition), we could support the ability to select any array as texture coordinates. | ||||||||
Relationships | ||||||
(0011204) Berk Geveci (administrator) 2008-04-09 11:58 |
I believe this is fixed. Utkarsh, can you set this to resolved if it is? |
(0011261) Ken Moreland (manager) 2008-04-10 16:09 |
I don't think 3 has been implemented. |
(0011262) Utkarsh Ayachit (administrator) 2008-04-10 16:13 |
(3) is pending, however is captured by BUG 0006768. Therefore, I am marking this resolved. |
(0011308) Alan Scott (manager) 2008-04-14 19:17 |
If there are bugs, we will find them with bug number 6768. Thus, I am marking this closed. |
2008-04-09 11:58 | Berk Geveci | Note Added: 0011204 | |
2008-04-09 11:58 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-04-09 11:58 | Berk Geveci | Category | => 3.4 |
2008-04-10 16:09 | Ken Moreland | Note Added: 0011261 | |
2008-04-10 16:11 | Utkarsh Ayachit | Relationship added | related to 0006768 |
2008-04-10 16:13 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-10 16:13 | Utkarsh Ayachit | Resolution | open => duplicate |
2008-04-10 16:13 | Utkarsh Ayachit | Note Added: 0011262 | |
2008-04-14 19:17 | Alan Scott | Status | @80@ => closed |
2008-04-14 19:17 | Alan Scott | Note Added: 0011308 | |
