0004794 | ParaView | (No Category) | public | 2007-04-05 10:00 | 2007-04-09 13:08 | ||||
Summary | 0004794: Element inspector does not udpate with time changes. | ||||||||
Description | Element inspector does not refresh data when time changes. Solution may be to make it a full-fledged view module. | ||||||||
(0007173) Utkarsh Ayachit (administrator) 2007-04-06 11:24 |
Now element inspector uses an actual view module. The view module (and its displays are registered but all operation are non-undoable and are never loaded from state. /cvsroot/ParaView3/ParaView3/Qt/Components/pqElementInspectorWidget.cxx,v <-- pqElementInspectorWidget.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqElementInspectorWidget.h,v <-- pqElementInspectorWidget.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExtractSelectionPanel.cxx,v <-- pqExtractSelectionPanel.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.165; previous revision: 1.164 /cvsroot/ParaView3/ParaView3/Qt/Components/pqStateLoader.cxx,v <-- pqStateLoader.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqViewManager.cxx,v <-- pqViewManager.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Qt/Core/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.69; previous revision: 1.68 /cvsroot/ParaView3/ParaView3/Qt/Core/pqElementInspectorViewModule.cxx,v <-- pqElementInspectorViewModule.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqElementInspectorViewModule.h,v <-- pqElementInspectorViewModule.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Core/pqGenericViewModule.cxx,v <-- pqGenericViewModule.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Core/pqGenericViewModule.h,v <-- pqGenericViewModule.h new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Core/pqStandardViewModules.cxx,v <-- pqStandardViewModules.cxx new revision: 1.5; previous revision: 1.4 |
