0004804 | ParaView | (No Category) | public | 2007-04-05 19:30 | 2007-04-06 09:22 | ||||
Reporter | Mark Richardson | ||||||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0004804: Choosing color preset updates color gradient but not function | ||||||||
Description | If you add a point to the tfe and then choose one of the preset color maps, the color gradient in the background shows the new color map, but the color points remain from the old color function. The scalar value field even shows the data from the new color function. I added a point on the yellow and dragged it left. Then, I chose the red to blue preset color map (using the choose preset button). After the dialog goes away, the background color gradient is correct, but the yellow point is still there. Clicking on the yellow point displays the value from the right endpoint, since the yellow had an id of 1 and that points to the new color function endpoint. | ||||||||
(0007171) Mark Richardson (reporter) 2007-04-05 19:33 |
The same thing also happens in reverse. I have a 4-color preset. If I choose that preset when the default 2-color red to blue is showing, I get the correct background with only two points showing. Clicking on the second point (the right endpoint) displays the value for the second point in the new color function. |
(0007172) Amy Squillacote (reporter) 2007-04-06 09:22 |
This has now been fixed. cvs revision 1.28 of vtkTransferFunctionEditorWidgetSimple1D.cxx |
