0004806 | ParaView | (No Category) | public | 2007-04-06 12:21 | 2008-04-09 11:59 | ||||
Summary | 0004806: Fix Unchecked properties convention. | ||||||||
Description | Fix uncheked properties as follows: Public can directly set unchecked properties. However when ever the regular (i.e. non-unchecked) property value is modified, the unchecked property value is synchronized with the regular value. Domains always use uncheked values. | ||||||||
(0011205) Berk Geveci (administrator) 2008-04-09 11:59 |
Maybe one day this will be fixed. |
2008-04-09 11:59 | Berk Geveci | Status | tabled => closed |
2008-04-09 11:59 | Berk Geveci | Note Added: 0011205 | |
2008-04-09 11:59 | Berk Geveci | Resolution | open => won't fix |
