0004843 | ParaView | (No Category) | public | 2007-04-11 10:37 | 2011-01-13 17:00 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0004843: Add an Extract Location over Time filter | ||||||||
Description | Add an Extract Location over Time filter | ||||||||
(0007687) user521 2007-05-18 10:57 |
I checked in the code yesterday. The new filter is called probe location over time. |
(0008481) Ken Moreland (manager) 2007-08-15 18:30 |
I ran into the following issues when trying this feature. When the plot showed up, it had a plot of vtkEAOTValidity, which is obviously some internal array that should not be displayed to the user. When running in client/server mode with a parallel server, an array called Cell's Point Ids was also added (and should not have been). Also, when running on the server (on the can.ex2 data set) I get a lot of the following error: ERROR: In C:\kmorel\src\ParaView3\VTK\Common\vtkDataArray.cxx, line 457 vtkIdTypeArray (0BF48AA0): The number of components do not match the number requested: 8 != 1 This is probably due to the fact that the exodus reader is loading everything into node 0. If I run the data through the D3 filter and then the Probe Location Over Time, I don't get these errors. |
(0009028) Utkarsh Ayachit (administrator) 2007-09-17 13:32 |
Changed vtkEAOTValidity array name to vtkValidPointMask to be consistent with probe. Removed "Cell's Point Ids" from the list of available arrays. /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkPExtractArraysOverTime.cxx,v <-- vtkPExtractArraysOverTime.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractTemporalFieldData.cxx,v <-- vtkExtractTemporalFieldData.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractArraysOverTime.cxx,v <-- vtkExtractArraysOverTime.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Core/pqLineChartRepresentation.cxx,v <-- pqLineChartRepresentation.cxx new revision: 1.14; previous revision: 1.13 |
(0009032) Utkarsh Ayachit (administrator) 2007-09-17 16:42 |
I could not reproduce the error anymore. Can you verify if it got fixed somehow? |
(0009037) Ken Moreland (manager) 2007-09-17 17:18 |
I now get the following errors with can.ex2 on black rose with 8 or more processes. ERROR: In C:\kmorel\src\ParaView3\VTK\Filtering\vtkStreamingDemandDrivenPipeline.cxx, line 698 vtkCompositeDataPipeline (0BEB3B30): The update extent specified in the information for output port 0 on algorithm vtkPolyLineToRectilinearGridFilter(0BEB2580) is 0 2147483647 0 2147483647 0 2147483647, which is outside the whole extent 0 -1 0 -1 0 -1. ERROR: In C:\kmorel\src\ParaView3\VTK\Filtering\vtkStreamingDemandDrivenPipeline.cxx, line 698 vtkCompositeDataPipeline (0BEB3B30): The update extent specified in the information for output port 0 on algorithm vtkPolyLineToRectilinearGridFilter(0BEB2580) is 0 2147483647 0 2147483647 0 2147483647, which is outside the whole extent 0 43 0 0 0 0. I have been placing the probe at (0,5,-14). |
(0009112) Utkarsh Ayachit (administrator) 2007-09-19 09:22 |
UpdateDependentDomains was getting called before input to the PolyLineToRectilinearGrid filter was set. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMXYPlotRepresentationProxy.cxx,v <-- vtkSMXYPlotRepresentationProxy.cxx new revision: 1.3; previous revision: 1.2 |
(0009293) Alan Scott (manager) 2007-09-25 19:56 |
Tested with Can. |
2007-08-13 14:24 | Berk Geveci | Status | @30@ => @80@ |
2007-08-15 18:30 | Ken Moreland | Status | @80@ => @20@ |
2007-08-15 18:30 | Ken Moreland | Resolution | fixed => reopened |
2007-08-15 18:30 | Ken Moreland | Note Added: 0008481 | |
2007-09-17 11:51 | Berk Geveci | Status | @20@ => tabled |
2007-09-17 11:51 | Berk Geveci | Assigned To | Dave DeMarle => Utkarsh Ayachit |
2007-09-17 13:32 | Utkarsh Ayachit | Note Added: 0009028 | |
2007-09-17 16:42 | Utkarsh Ayachit | Note Added: 0009032 | |
2007-09-17 16:42 | Utkarsh Ayachit | Status | tabled => @20@ |
2007-09-17 17:18 | Ken Moreland | Note Added: 0009037 | |
2007-09-19 09:22 | Utkarsh Ayachit | Status | @20@ => @80@ |
2007-09-19 09:22 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-09-19 09:22 | Utkarsh Ayachit | Note Added: 0009112 | |
2007-09-25 19:56 | Alan Scott | Status | @80@ => closed |
2007-09-25 19:56 | Alan Scott | Note Added: 0009293 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
