0004916 | ParaView | (No Category) | public | 2007-04-24 12:10 | 2007-09-12 21:28 | ||||
Assigned To | Yumin Yuan | ||||||||
Summary | 0004916: Wrong mouse cursor after multiview + selection | ||||||||
Description | The error occurs when you have two 3D views up at one time. Perform a selection in one view. After the selection is complete, the mouse cursor in the opposite view becomes the selection cursor. | ||||||||
(0007497) Clinton Stimpson (developer) 2007-04-26 15:53 |
The selection manager is tied to the active view, and the cursor change happens on the active view. Things get out of sync if you change active views to do a selection. Should the selection manager rely on the active view? Or just work with whatever view the user does selection in? |
(0007498) Ken Moreland (manager) 2007-04-26 15:56 |
I think it is reasonable for the user to expect selection strokes to work in unselected views (just as movement strokes work). I would much rather have my cursor occasionally be wrong than for selection to occasionally fail for some esoteric reason I don't understand. |
(0008444) Berk Geveci (administrator) 2007-08-13 17:01 |
This is probably already fixed. Please verify. |
(0008896) Yumin Yuan (developer) 2007-09-07 16:41 |
This behavior is unrepeatable with the new Selection framework/functionalities. |
2007-08-13 17:01 | Berk Geveci | Note Added: 0008444 | |
2007-08-13 17:01 | Berk Geveci | Assigned To | Clinton Stimpson => Yumin Yuan |
2007-08-13 17:01 | Berk Geveci | Priority | normal => high |
2007-09-07 16:41 | Yumin Yuan | Status | tabled => @80@ |
2007-09-07 16:41 | Yumin Yuan | Resolution | open => fixed |
2007-09-07 16:41 | Yumin Yuan | Note Added: 0008896 | |
2007-09-12 21:28 | Alan Scott | Status | @80@ => closed |
