0004955 | ParaView | (No Category) | public | 2007-04-30 16:44 | 2008-04-09 12:11 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0004955: crash opening Xdmf files with builtin connection and mpi | ||||||||
Description | ParaView3 cannot open Test1.xmf. I get lots of errors. | ||||||||
(0007527) Clinton Stimpson (developer) 2007-04-30 16:46 |
Nor will it open any file with "Collection" in its name in ParaView2/Data/Iron XDMF/ directory. |
(0007562) Clinton Stimpson (developer) 2007-05-04 15:30 |
If you build ParaView with MPI and use the builtin connection, one cannot open *any* Xdmf file. |
(0007563) Clinton Stimpson (developer) 2007-05-04 16:01 |
Problem is in Utilities/Xdmf/libsrc/XdmfHDF.cxx line 664. It assumes MPI has been initialized. I can also put SERIAL in my xmf file to make it read without MPI. |
(0007571) Berk Geveci (administrator) 2007-05-07 13:19 |
Clint, Utkarsh and I cannot reproduce this. He tried on Linux, I tried on Mac. It works fine. Can you provide more information? Did you build your own hdf5 by any chance? |
(0007573) Berk Geveci (administrator) 2007-05-07 13:23 |
Do you have HDF5_ENABLE_PARALLEL on? |
(0007574) Clinton Stimpson (developer) 2007-05-07 13:30 |
Yes, HDF5_ENABLE_PARALLEL is on. I can try it with a clean build sometime. |
(0007589) Clinton Stimpson (developer) 2007-05-07 19:23 |
Ok, I turned HDF5_ENABLE_PARALLEL off and it works fine. |
2008-04-09 12:11 | Berk Geveci | Status | tabled => closed |
2008-04-09 12:11 | Berk Geveci | Resolution | open => fixed |
