0005095 | ParaView | (No Category) | public | 2007-05-27 15:06 | 2008-04-09 20:50 | ||||
Reporter | Stewart Dickson | ||||||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0005095: Application creashes -- vtkUnsignedCharArray: Unable to allocate (1.3Gbytes) | ||||||||
Description | ParaView 3.0.0 (beta) x86 (32-bit) version for Windows: ERROR: in c:\berk\work\releasebuilds\paraview3\vtk\common\vtkDataArrayTemplate.txx, line 95 vtkUnsignedCharArray (0AD6B458): Unable to allocate 1287549288 elements of size 1 bytes paraview.exe has encountered a problem and needs to close. We are sorry for the inconvenience. Platform: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz 2.40GHz, 8.00 GB of RAM Microsoft Windows XP Professional x64 Edition | ||||||||
Attached Files | ea5c_appcompat.txt [^] (0 bytes) 1969-12-31 19:00 | ||||||||
(0007727) Stewart Dickson (reporter) 2007-05-29 12:41 |
In $ gdb "/cygdrive/c/Program Files/VTK 5.0/bin/vtk" GNU gdb 6.5.50.20060706-cvs (cygwin-special) ERROR: In C:\Dashboards\...\Filtering\vtkImage... vtkImageData[02C79880]: Coordinate [0,0, 1006] out side of array [max = -...ERROR: In C:\Dashboards\...\Filtering\vtkImage... vtkImageData[02C79880]: Coordinate [511, 511, 1944] out side of array [ma... Program received signal SIGSEGV, Segmentation fault. 0x0113ce9e in vtk!?vtkParallelRenderManagerCppCommand@@YAHPAVvtkParallelRenderMa nager@@PAUTcl_Interp@@HQAPAD@Z () |
(0011238) Berk Geveci (administrator) 2008-04-09 20:50 |
It looks like the dataset is too large to fit in memory. |
2008-04-09 20:50 | Berk Geveci | Status | tabled => closed |
2008-04-09 20:50 | Berk Geveci | Note Added: 0011238 | |
2008-04-09 20:50 | Berk Geveci | Resolution | open => no change required |
