0005166 | ParaView | (No Category) | public | 2007-06-11 12:26 | 2007-09-12 17:57 | ||||
Summary | 0005166: Charting vectors | ||||||||
Description | In the charting views, it should be possible to chart vectors by selecting the x, y, or z component or by selecting the magnitude. This feature was requested by users during the ParaView Summit on 6/5/2007. | ||||||||
(0008840) Mark Richardson (reporter) 2007-09-05 13:38 |
Vector arrays are now available in the line chart. The user can select the magnitude or any of the components. The vector arrays can be used for the x or y axis. |
(0008951) Ken Moreland (manager) 2007-09-12 16:29 |
How do you plot the components of a vector on the Y axis. I cannot figure out any way to do this. Example: I load up disk_out_ref (with all the variables) and select Plot Over Line. One of the variables plotted is the vector V. I presume the value I am getting is the magnitude. But I don't know how to get the x, y, or z component. |
(0008956) Mark Richardson (reporter) 2007-09-12 17:38 |
The third column in the list of arrays shows which component is being used. You can also select-click to edit. Choose the component from the combobox. You may have to scroll the view to the right in order to see the component column. |
(0008958) Ken Moreland (manager) 2007-09-12 17:57 |
My bad. On my Windows XP using the default layout, the second column went right up to the edge of the widget, and I did not notice that a third column was added. |
2007-08-23 10:37 | Berk Geveci | Priority | normal => high |
2007-09-05 13:38 | Mark Richardson | Status | tabled => @80@ |
2007-09-05 13:38 | Mark Richardson | Resolution | open => fixed |
2007-09-05 13:38 | Mark Richardson | Note Added: 0008840 | |
2007-09-12 13:23 | Alan Scott | Status | @80@ => closed |
2007-09-12 16:29 | Ken Moreland | Status | closed => @20@ |
2007-09-12 16:29 | Ken Moreland | Resolution | fixed => reopened |
2007-09-12 16:29 | Ken Moreland | Note Added: 0008951 | |
2007-09-12 17:38 | Mark Richardson | Note Added: 0008956 | |
2007-09-12 17:57 | Ken Moreland | Status | @20@ => closed |
2007-09-12 17:57 | Ken Moreland | Note Added: 0008958 | |
2007-09-12 17:57 | Ken Moreland | Resolution | reopened => fixed |
