0005182 | ParaView | (No Category) | public | 2007-06-13 19:15 | 2007-09-13 16:15 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005182: Typing in 3D widget entry box should not cause render | ||||||||
Description | Because rendering take some time when data is large, each keystroke in a 3D widget related entry box should not cause re-render. Instead tabbing out or something similar should render. The same is true for any display page entry (including the one for text source) | ||||||||
(0007898) Clinton Stimpson (developer) 2007-06-15 18:40 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqHandleWidget.cxx,v <-- pqHandleWidget.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqImplicitPlaneWidget.cxx,v <-- pqImplicitPlaneWidget.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLineWidget.cxx,v <-- pqLineWidget.cxx new revision: 1.16; previous revision: 1.15 I like ripping code out :) |
(0007941) Ken Moreland (manager) 2007-06-26 11:07 |
Now the 3D widget is updated (or rather renderings happen) too infrequently. Now when you update the 2D widget, the result is never shown in the 3D view until the user wiggles the camera or some other event that causes a re-render takes place. I think the idea is that the display does not re-render for every keystroke but does re-render when focus changes from one 2D widget to the next. For example, consider the point widget, which has three line edits in the object inspector. The user wants to set the values in the object inspector to 100, 100, 100. As the user types 1 then 0 then 0 in the first box, the 3D display is not updated. Then the user hits tab to go to the next box, and the 3D view is updated. |
(0007942) Clinton Stimpson (developer) 2007-06-26 11:24 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqHandleWidget.cxx,v <-- pqHandleWidget.cxx new revision: 1.16; previous revision: 1.15 /cvsroot/ParaView3/ParaView3/Qt/Components/pqLineWidget.cxx,v <-- pqLineWidget.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/pqImplicitPlaneWidget.cxx,v <-- pqImplicitPlaneWidget.cxx new revision: 1.20; previous revision: 1.19 Put the code back. |
(0007943) Clinton Stimpson (developer) 2007-06-26 11:32 |
It already did that, so what's the problem? |
(0008614) Berk Geveci (administrator) 2007-08-23 10:41 |
I think the display page still has problems. |
(0008810) Berk Geveci (administrator) 2007-09-03 10:56 |
I verified that the Display properties panel still has this problem. |
(0008857) Clinton Stimpson (developer) 2007-09-06 13:37 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayProxyEditor.cxx,v <-- pqDisplayProxyEditor.cxx new revision: 1.42; previous revision: 1.41 |
(0008979) Alan Scott (manager) 2007-09-13 16:15 |
I think that this is fixed. I created a sources/ point source. I then changed the point to 100 <tab> 100 <tab> 100 <tab>. 3d window only updated during the tabs. |
2007-08-23 10:41 | Berk Geveci | Note Added: 0008614 | |
2007-08-23 10:41 | Berk Geveci | Assigned To | Clinton Stimpson => Berk Geveci |
2007-08-23 10:41 | Berk Geveci | Priority | normal => high |
2007-08-23 10:41 | Berk Geveci | Status | backlog => tabled |
2007-09-03 10:56 | Berk Geveci | Note Added: 0008810 | |
2007-09-03 10:56 | Berk Geveci | Assigned To | Berk Geveci => Clinton Stimpson |
2007-09-06 13:37 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-06 13:37 | Clinton Stimpson | Resolution | reopened => fixed |
2007-09-06 13:37 | Clinton Stimpson | Note Added: 0008857 | |
2007-09-13 16:15 | Alan Scott | Status | @80@ => closed |
2007-09-13 16:15 | Alan Scott | Note Added: 0008979 | |
