0005187 | ParaView | (No Category) | public | 2007-06-14 10:49 | 2007-06-26 11:09 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005187: Format of radius in streamtracer is to restricted | ||||||||
Description | For the streamlines, the radius input can only have 2 digits which is problematic when having a mesh in meter and a inlet hole of a few millimetres (impossible to enter 0.005 for instance) This should be fixed for all floating point numbers. The validator should not limit the number of digits. | ||||||||
(0007889) Clinton Stimpson (developer) 2007-06-15 12:49 |
Oops. That spin box was missed when we replaced them all with validated line edits. |
(0007890) Clinton Stimpson (developer) 2007-06-15 12:58 |
/cvsroot/ParaView3/ParaView3/Qt/Components/pqPointSourceWidget.cxx,v <-- pqPointSourceWidget.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqPointSourceControls.ui,v <-- pqPointSourceControls.ui new revision: 1.3; previous revision: 1.2 |
