0005196 | ParaView | (No Category) | public | 2007-06-14 22:05 | 2007-09-17 18:28 | ||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0005196: Simple edge sets crashes. | ||||||||
Description | PV 3.0.1 crashes consistantly and easily when trying to use sidesets and nodesets. Only seems to happen on XP. I replicated this with the Kitware 3.0.1 download. Replicate as follows: * Open Can.exo * Turn on all variables. * Turn off all blocks. * Turn on all sidesets/ nodesets. * Hit apply. * Left click, in main window - trying to rotate. Seg fault. "Warning: In C:/berk/work/srleasebuilds/paraview3/vtk/common/vtkDataArrayTemplate.txx linee 347 vtkfloatArray: Input and output array data types do not match. I am not sure how important this one is, since it seems to be XP only, so will set it very high with the idea that I don't want it falling through the cracks. alan | ||||||||
Relationships | ||||||
(0007888) Alan Scott (manager) 2007-06-15 12:34 |
Lots of new information. * Nodesets is what is crashing. * Must have "Use Immediate Mode Rendering" turned on, AND "LOD Threshold" set to 0. Conclusion: anyone with large data, who is immediate mode rendering nodesets, will have this crash. Workaround - turn off LOD Thresholding. I am moving this to a priority 4, since there are workarounds. alan |
(0007895) Clinton Stimpson (developer) 2007-06-15 15:22 |
This looks the same as bug 0004191 |
(0008425) Berk Geveci (administrator) 2007-08-13 14:41 |
Should probably run this through a memory checker. |
(0008941) Amy Squillacote (reporter) 2007-09-12 11:45 |
This problem has now been fixed. The problem was the result of a typo: when you're copying cell data, it should be from the input to the output, not the output to the output. /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkQuadricClustering.cxx,v <-- vtkQu adricClustering.cxx new revision: 1.78; previous revision: 1.77 |
2007-08-13 14:41 | Berk Geveci | Note Added: 0008425 | |
2007-09-11 16:39 | Berk Geveci | Relationship added | duplicate of 0004191 |
2007-09-11 16:39 | Berk Geveci | Assigned To | Berk Geveci => Amy Squillacote |
2007-09-12 11:45 | Amy Squillacote | Status | tabled => @80@ |
2007-09-12 11:45 | Amy Squillacote | Resolution | open => fixed |
2007-09-12 11:45 | Amy Squillacote | Note Added: 0008941 | |
2007-09-17 18:28 | Alan Scott | Status | @80@ => closed |
