0005305 | ParaView | (No Category) | public | 2007-07-06 15:53 | 2007-07-17 10:48 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005305: too many renderers reported in UndoRedo2 test | ||||||||
Description | Start ParaView in client server mode with the compositing threshold set to 0. Select Play Test from the Tools menu and browse to the UndoRedo2.xml tst (in PV3/Applications/Client/Testing/XML). The 2nd time the render window is split in 2, vtkParallelRenderManager (on the server) reports that there are too many renderers. | ||||||||
(0008014) Amy Squillacote (reporter) 2007-07-09 09:11 |
This also happens in client - data server - render server mode with the compositing threshold set to 0. |
(0008018) Utkarsh Ayachit (administrator) 2007-07-09 15:21 |
Another one of those bug that was undiscovered for years together and exposed when composite rendering threshold=0. Renderers were not removed from the server side render sync manager when a view was destroyed. Fixed that. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientServerRenderViewProxy.cxx,v <-- vtkSMClientServerRenderViewProxy.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientServerRenderViewProxy.h,v <-- vtkSMClientServerRenderViewProxy.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTCompositeViewProxy.cxx,v <-- vtkSMIceTCompositeViewProxy.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTCompositeViewProxy.h,v <-- vtkSMIceTCompositeViewProxy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIceTDesktopRenderViewProxy.cxx,v <-- vtkSMIceTDesktopRenderViewProxy.cxx new revision: 1.10; previous revision: 1.9 |
