0005307 | ParaView | (No Category) | public | 2007-07-06 16:40 | 2008-04-09 21:06 | ||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0005307: Volume rendering doesn't work with render-server | ||||||||
Description | Volume rendering (in general, when ordered compositing is on) fails when running with separate data server/render server. | ||||||||
(0008027) Utkarsh Ayachit (administrator) 2007-07-11 15:07 |
Is volume rendering in this mode supposed to work? MPIMoveData cannot deliver anything but vtkPolyData to the render server from the data server. |
(0008580) Ken Moreland (manager) 2007-08-22 09:55 |
This has actually never worked so far for exactly the reason you say. When I made the initial implementation I stopped trying to get data server/render server working because I didn't want to go through the heartache of implementing a repartitioning method. I decided it was not worth doing myself, at least in the short term, because (1) Sandia does not use the data server / render server mode and (2) due to the amount of data that would have to be passed between the two servers I am not sure there is any logic in doing volume rendering in this mode. |
(0011245) Berk Geveci (administrator) 2008-04-09 21:06 |
This is a known limitation. We don't intend to fix it. |
2007-08-22 09:55 | Ken Moreland | Note Added: 0008580 | |
2008-04-09 21:06 | Berk Geveci | Status | tabled => closed |
2008-04-09 21:06 | Berk Geveci | Note Added: 0011245 | |
2008-04-09 21:06 | Berk Geveci | Resolution | open => won't fix |
