0005315 | ParaView | (No Category) | public | 2007-07-09 11:15 | 2007-09-18 16:13 | ||||
Summary | 0005315: Parallel structured volume rendering not working | ||||||||
Description | Parallel structured volume rendering does not seem to be working. It does not seem to be compositing in the correct order. Instead, the composite order seems to not change when the view changes. The compositing order seems fine when unstructured volume rendering is used. | ||||||||
Attached Files | vol_render_bug.pvsm [^] (47,429 bytes) 1969-12-31 19:00 vol_render_bug.png [^] (90,783 bytes) 1969-12-31 19:00 | ||||||||
(0008017) Ken Moreland (manager) 2007-07-09 11:17 |
I've attached a state file that tickles the bug and an image of what it looks like. |
(0008942) Utkarsh Ayachit (administrator) 2007-09-12 12:01 |
The kdtree generated was based on extents of the structured data rather than its bounds. Fixed the generated to convert the extents to bounds using the image data origin and spacing. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkKdTreeGenerator.h,v <-- vtkKdTreeGenerator.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkKdTreeGenerator.cxx,v <-- vtkKdTreeGenerator.cxx new revision: 1.3; previous revision: 1.2 |
2007-08-13 14:45 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-09-12 12:01 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-12 12:01 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-12 12:01 | Utkarsh Ayachit | Note Added: 0008942 | |
2007-09-18 16:13 | Ken Moreland | Status | @80@ => closed |
