0005362 | ParaView | (No Category) | public | 2007-07-18 16:48 | 2007-11-01 20:35 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005362: shared forwarding doesn't work on Mac OS X | ||||||||
Description | Grabbing 3.0 from cvs, turning shared libs on, and building gives a build with shared forwarding. That setup doesn't work on the Mac. And that's the first setup many Mac ParaView builders will see. | ||||||||
(0009289) Clinton Stimpson (developer) 2007-09-25 14:59 |
Is this the right fix? So Mac defaults to rpath on all the time. Index: CMakeLists.txt =================================================================== RCS file: /cvsroot/ParaView3/ParaView3/CMakeLists.txt,v retrieving revision 1.67 diff -u -r1.67 CMakeLists.txt --- CMakeLists.txt 25 Sep 2007 13:23:48 -0000 1.67 +++ CMakeLists.txt 25 Sep 2007 18:57:57 -0000 @@ -53,13 +53,13 @@ SET(PARAVIEW_VERSION_FULL "${PARAVIEW_VERSION}.${PARAVIEW_VERSION_PATCH}") # See VTK/CMakeLists.txt for an explanation of this default selection. -IF(PARAVIEW_VERSION_MINOR MATCHES "[02468]$") +IF(PARAVIEW_VERSION_MINOR MATCHES "[02468]$" AND NOT APPLE) # This is a release version. Default to not use rpath. SET(VTK_USE_RPATH_DEFAULT OFF) -ELSE(PARAVIEW_VERSION_MINOR MATCHES "[02468]$") +ELSE(PARAVIEW_VERSION_MINOR MATCHES "[02468]$" AND NOT APPLE) # This is a development version. Default to use rpath. SET(VTK_USE_RPATH_DEFAULT ON) -ENDIF(PARAVIEW_VERSION_MINOR MATCHES "[02468]$") +ENDIF(PARAVIEW_VERSION_MINOR MATCHES "[02468]$" AND NOT APPLE) ######################################################################### # build VTK/Qt support |
(0009615) Alan Scott (manager) 2007-11-01 20:35 |
I am marking this closed, although I have not tested it on a Mac. |
2007-09-25 14:59 | Clinton Stimpson | Note Added: 0009289 | |
2007-10-11 13:20 | Ken Moreland | Status | tabled => @80@ |
2007-10-11 13:20 | Ken Moreland | Resolution | open => fixed |
2007-11-01 20:35 | Alan Scott | Status | @80@ => closed |
2007-11-01 20:35 | Alan Scott | Note Added: 0009615 | |
