0005368 | ParaView | (No Category) | public | 2007-07-19 16:35 | 2007-09-13 22:21 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005368: crash with multi input filter dialog | ||||||||
Description | create box then sphere source, filters -> Resample with Dataset In the dialog, click on "CubeSource1" in left pane. I get a crash. I also noticed that if I hit cancel, I get an output window saying it couldn't make the filter. That message is unecessary. | ||||||||
Relationships | ||||||
(0008920) Mark Richardson (reporter) 2007-09-11 15:19 |
The pipeline model in the dialog did not have the correct connections for the filter being created. I added the connections in to the model before it is passed into the dialog. This cleared up the crash. I also fixed an order problem in the pipeline model's disconnect method that was causing a crash when a source was connected multiple times to the same filter. |
2007-08-29 15:11 | Berk Geveci | Priority | normal => high |
2007-08-29 15:11 | Berk Geveci | Category | => 3.2 |
2007-09-03 11:01 | Berk Geveci | Relationship added | related to 0004975 |
2007-09-11 15:19 | Mark Richardson | Status | tabled => @80@ |
2007-09-11 15:19 | Mark Richardson | Resolution | open => fixed |
2007-09-11 15:19 | Mark Richardson | Note Added: 0008920 | |
2007-09-13 22:21 | Alan Scott | Status | @80@ => closed |
