0005412 | ParaView | (No Category) | public | 2007-07-26 12:12 | 2008-04-09 21:20 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0005412: Python path tests | ||||||||
Description | Please add some tests for a correct python path (that includes the paraview module). Specifically doing an "import paraview" from the following should work without the user needing to set the python path. 1. pvpython 2. programmable filter 3. python GUI window from command line 4. python GUI window from ParaView Mac Bundle | ||||||||
(0011248) Berk Geveci (administrator) 2008-04-09 21:20 |
I am closing this. We are testing python as much as we can through the testing. The rest has to be done manually after each release (which I do). |
2007-09-20 14:04 | Berk Geveci | Priority | high => normal |
2008-04-09 21:20 | Berk Geveci | Status | tabled => closed |
2008-04-09 21:20 | Berk Geveci | Note Added: 0011248 | |
2008-04-09 21:20 | Berk Geveci | Resolution | open => fixed |
