0005418 | ParaView | (No Category) | public | 2007-07-27 10:33 | 2007-08-30 15:39 | ||||
Summary | 0005418: Invalid formats presented when saving anim on server | ||||||||
Description | When you select the option to disconnect the client from the server when saving an animation, it offers all of the file formats available on the client even when they are not available on the server. For example, when I am using my Windows client and my Linux server (compiled without FFMPEG), the file chooser lets me select avi as the file format. If I try to save as an avi file, I get the following errors on the server. Process id: 0 >> ERROR: In /projects/kmorel/dashboard/ParaView3Experimental/Servers/ServerManager/vtkSMAnimationSceneImageWriter.cxx, line 337 vtkSMAnimationSceneImageWriter (0xff5a30): Unknown extension .avi Process id: 0 >> ERROR: In /projects/kmorel/dashboard/ParaView3Experimental/Servers/ServerManager/vtkSMServerSideAnimationPlayer.cxx, line 154 vtkSMServerSideAnimationPlayer (0x10499e0): Failed to save animation. Of course, the animation is never produced. | ||||||||
(0008628) Utkarsh Ayachit (administrator) 2007-08-23 15:02 |
vtkPVServerInformation was extended to indicate AVI support. Now animation manager uses the vtkPVServerInformation to determine AVI support when saving animation. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.cxx,v <-- pqAnimationManager.cxx new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVServerInformation.cxx,v <-- vtkPVServerInformation.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVServerInformation.h,v <-- vtkPVServerInformation.h new revision: 1.8; previous revision: 1.7 |
(0008728) Ken Moreland (manager) 2007-08-28 17:24 |
This change does not seem to have made it all the way to the GUI. I can still select AVI in the file dialog chooser and I still get the same error if I try to use it. |
(0008732) Utkarsh Ayachit (administrator) 2007-08-29 08:59 |
Forgot to update AVISupport flag in AddInformation. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVServerInformation.cxx,v <-- vtkPVServerInformation.cxx new revision: 1.12; previous revision: 1.11 |
2007-08-13 14:59 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-08-23 15:02 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-23 15:02 | Utkarsh Ayachit | Resolution | open => fixed |
2007-08-23 15:02 | Utkarsh Ayachit | Note Added: 0008628 | |
2007-08-28 17:24 | Ken Moreland | Status | @80@ => @20@ |
2007-08-28 17:24 | Ken Moreland | Resolution | fixed => reopened |
2007-08-28 17:24 | Ken Moreland | Note Added: 0008728 | |
2007-08-29 08:59 | Utkarsh Ayachit | Status | @20@ => @80@ |
2007-08-29 08:59 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-08-29 08:59 | Utkarsh Ayachit | Note Added: 0008732 | |
2007-08-30 15:39 | Ken Moreland | Status | @80@ => closed |
