0005475 | ParaView | (No Category) | public | 2007-08-09 16:54 | 2007-09-11 16:24 | ||||
Summary | 0005475: ParaView server timeout warning doesn't work | ||||||||
Description | ParaView 2.6 had a warning that is displayed to the user when the server was about to timeout. Another warning occurs as the server DOES timeout. This has been lost in PV 3.0, and desperately needs to be fixed. 3.2 is soon enough. | ||||||||
Relationships | ||||||
(0008452) Ken Moreland (manager) 2007-08-14 12:32 |
Note that there are at least two different ways to specify a connection to the server: through command line options and through the XML-specified GUI. For the command line approach, there should be support for a --server-time flag as there was in PV 2.6. For the GUI, there should be a way to specify in the XML which option specifies the server time. |
(0008831) Utkarsh Ayachit (administrator) 2007-09-04 16:45 |
--timeout option when specified on the pvserver or pvdataserver process causes the client to show warning message boxes 5 and 1 minute before the timeout since the connection with the server is established. /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVOptions.h,v <-- vtkPVOptions.h new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVServerInformation.cxx,v <-- vtkPVServerInformation.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVServerInformation.h,v <-- vtkPVServerInformation.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVOptions.cxx,v <-- vtkPVOptions.cxx new revision: 1.42; previous revision: 1.41 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServer.h,v <-- pqServer.h new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Core/pqServer.cxx,v <-- pqServer.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.h,v <-- pqMainWindowCore.h new revision: 1.74; previous revision: 1.73 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.210; previous revision: 1.209 |
2007-08-09 16:54 | Alan Scott | New Issue | |
2007-08-14 12:32 | Ken Moreland | Note Added: 0008452 | |
2007-08-29 15:50 | Berk Geveci | Assigned To | => Berk Geveci |
2007-08-29 15:50 | Berk Geveci | Priority | normal => high |
2007-08-29 15:50 | Berk Geveci | Status | backlog => tabled |
2007-08-29 15:50 | Berk Geveci | Category | => 3.2 |
2007-09-03 10:33 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
2007-09-03 10:57 | Berk Geveci | Relationship added | has duplicate 0005163 |
2007-09-04 16:45 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-04 16:45 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-04 16:45 | Utkarsh Ayachit | Note Added: 0008831 | |
2007-09-11 16:24 | Alan Scott | Status | @80@ => closed |
