0005486 | ParaView | (No Category) | public | 2007-08-10 11:03 | 2007-08-14 09:27 | ||||
Summary | 0005486: File browser navigate forward stack backward | ||||||||
Description | Open the file browser (by selecting to load data or something) and do the following. Use the browser to descend down into several directories. Now use the navigate back to go back up the directory tree. This button will correctly navigate back up one directory at a time. Once you get back to the top, start using the navigate forward button. You should be able to navigate back up one directory at a time. Instead, the first click places you deep into the directory stack and subsequent operations moves up the directory like the back button did. I think the items are being placed on the navigate forward stack backwards. | ||||||||
(0008408) Clinton Stimpson (developer) 2007-08-10 11:23 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqFileDialog.cxx,v <-- pqFileDialog.cxx new revision: 1.17; previous revision: 1.16 |
2007-08-10 11:03 | Ken Moreland | New Issue | |
2007-08-10 11:22 | Clinton Stimpson | Status | backlog => tabled |
2007-08-10 11:22 | Clinton Stimpson | Assigned To | => Clinton Stimpson |
2007-08-10 11:23 | Clinton Stimpson | Status | tabled => @80@ |
2007-08-10 11:23 | Clinton Stimpson | Resolution | open => fixed |
2007-08-10 11:23 | Clinton Stimpson | Note Added: 0008408 | |
2007-08-14 09:27 | Ken Moreland | Status | @80@ => closed |
