0005506 | ParaView | (No Category) | public | 2007-08-15 17:20 | 2007-10-01 20:39 | ||||
Summary | 0005506: Cannot slide keyframe values in animation view track | ||||||||
Description | The original design document for the animation view (http://www.paraview.org/ParaQ/index.php/Animation_GUI [^]) specified the ability to provide simple modification of keyframes by dragging the edges of boxes in the tracks to new times. This feature is not yet implemented. | ||||||||
Relationships | ||||||
(0009326) Clinton Stimpson (developer) 2007-09-28 12:57 |
Can I get some feedback on this? I wasn't sure whether to snap the interaction in "sequence" mode and "snap to timesteps" mode. Also, one can move the current time bar. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.cxx,v <-- pqAnimationViewWidget.cxx new revision: 1.29; previous revision: 1.28 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.h,v <-- pqAnimationViewWidget.h new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.cxx,v <-- pqAnimationModel.cxx new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.h,v <-- pqAnimationModel.h new revision: 1.8; previous revision: 1.7 |
(0009334) Ken Moreland (manager) 2007-09-28 13:24 |
Very cool. Yes, the snapping should occur in sequence and snap to timesteps modes. In either mode, the keyframes should snap to the points of time the animation will visit. Also, in all modes, snapping to the current time and to keyframe times of other tracks should also work. I also found a bug. You can only drag the tracks properly if the start time is 0 and the end time is 1. |
(0009336) Clinton Stimpson (developer) 2007-09-28 14:53 |
Ok, it snaps now. And interaction with a non-(0,1) range is fixed. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.cxx,v <-- pqAnimationViewWidget.cxx new revision: 1.30; previous revision: 1.29 /cvsroot/ParaView3/ParaView3/Qt/Components/pqComparativeTracksWidget.cxx,v <-- pqComparativeTracksWidget.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationKeyFrame.cxx,v <-- pqAnimationKeyFrame.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationKeyFrame.h,v <-- pqAnimationKeyFrame.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.cxx,v <-- pqAnimationModel.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.h,v <-- pqAnimationModel.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Widgets/Testing/Animation.cxx,v <-- Animation.cxx new revision: 1.3; previous revision: 1.2 |
(0009337) Clinton Stimpson (developer) 2007-09-28 15:46 |
Snap to other keyframe times. Also prevent going past other keyframe times on the same track. /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.cxx,v <-- pqAnimationModel.cxx new revision: 1.26; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.h,v <-- pqAnimationModel.h new revision: 1.10; previous revision: 1.9 |
(0009338) Clinton Stimpson (developer) 2007-09-28 17:15 |
Now in 3.2. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.cxx,v <-- pqAnimationViewWidget.cxx new revision: 1.28.4.1; previous revision: 1.28 /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationViewWidget.h,v <-- pqAnimationViewWidget.h new revision: 1.10.4.1; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqComparativeTracksWidget.cxx,v <-- pqComparativeTracksWidget.cxx new revision: 1.10.4.1; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationKeyFrame.cxx,v <-- pqAnimationKeyFrame.cxx new revision: 1.8.4.1; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationKeyFrame.h,v <-- pqAnimationKeyFrame.h new revision: 1.5.4.1; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.cxx,v <-- pqAnimationModel.cxx new revision: 1.23.4.1; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.h,v <-- pqAnimationModel.h new revision: 1.7.4.1; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Widgets/Testing/Animation.cxx,v <-- Animation.cxx new revision: 1.2.4.1; previous revision: 1.2 |
(0009359) Alan Scott (manager) 2007-10-01 20:39 |
Seemed to work for me. (Not totally sure if I actually understood and tested the fix...) Tested in 3.2 and cvs head. Local ParaView. |
2007-08-15 17:20 | Ken Moreland | New Issue | |
2007-08-15 17:21 | Ken Moreland | Relationship added | related to 0003340 |
2007-08-15 17:21 | Ken Moreland | Assigned To | => Clinton Stimpson |
2007-08-15 17:21 | Ken Moreland | Status | backlog => tabled |
2007-09-28 12:57 | Clinton Stimpson | Note Added: 0009326 | |
2007-09-28 12:57 | Clinton Stimpson | Status | tabled => @20@ |
2007-09-28 13:24 | Ken Moreland | Note Added: 0009334 | |
2007-09-28 14:53 | Clinton Stimpson | Note Added: 0009336 | |
2007-09-28 14:53 | Clinton Stimpson | Status | @20@ => tabled |
2007-09-28 15:46 | Clinton Stimpson | Note Added: 0009337 | |
2007-09-28 17:15 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-28 17:15 | Clinton Stimpson | Resolution | open => fixed |
2007-09-28 17:15 | Clinton Stimpson | Note Added: 0009338 | |
2007-10-01 20:39 | Alan Scott | Status | @80@ => closed |
2007-10-01 20:39 | Alan Scott | Note Added: 0009359 | |
