0005507 | ParaView | (No Category) | public | 2007-08-15 17:26 | 2007-08-21 11:58 | ||||
Summary | 0005507: Out-of-order keyframes | ||||||||
Description | The Animation Keyframes dialog box allows you to set arbitrary values for the time of each keyframe. This is good, but results in the possibility of keyframes that are out of order. The keyframes should be reordered whenever the time of one is moved outside of the range of the surrounding keyframes. The correct interpolation used becomes a bit ambiguous. Just pick values that make sense based on the existing interpolation. They are easy enough to change if they are wrong. | ||||||||
Relationships | ||||||
(0008525) Clinton Stimpson (developer) 2007-08-20 14:34 |
They are re-ordered now. /cvsroot/ParaView3/ParaView3/Qt/Components/pqKeyFrameEditor.cxx,v <-- pqKeyFrameEditor.cxx new revision: 1.20; previous revision: 1.19 |
2007-08-15 17:26 | Ken Moreland | New Issue | |
2007-08-15 17:26 | Ken Moreland | Relationship added | related to 0003340 |
2007-08-15 17:28 | Ken Moreland | Assigned To | => Clinton Stimpson |
2007-08-15 17:28 | Ken Moreland | Status | backlog => tabled |
2007-08-20 14:34 | Clinton Stimpson | Status | tabled => @80@ |
2007-08-20 14:34 | Clinton Stimpson | Resolution | open => fixed |
2007-08-20 14:34 | Clinton Stimpson | Note Added: 0008525 | |
2007-08-21 11:58 | Ken Moreland | Status | @80@ => closed |
