0005513ParaView(No Category)public2007-08-15 18:002007-08-21 12:12
ReporterKen Moreland
Assigned ToClinton Stimpson
PriorityhighSeverityminorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0005513: Default keyframe values sometimes strange
DescriptionDo the following
1. Create a sphere source.
2. Create a keyframe for the StartTheta property. The default values go from 0 to 360 (as you would expect).
3. Create a keyframe for the Radius property. The default values for this also go from 0 to 360, which is not what one would expect.
The values for the radius are clearly taken from the start theta. If you create the radius track first, the values go from 0 to 0.5, which is much more logical.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
related to 0003340closedClinton Stimpson Design new animation UI panels
  Notes
(0008517)
Clinton Stimpson (developer)
2007-08-20 13:57
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorKeyFrameValue.cxx,v <-- pqSignalAdaptorKeyFrameValue.cxx
new revision: 1.6; previous revision: 1.5
 Issue History
2007-08-15 18:00 Ken Moreland New Issue
2007-08-15 18:00 Ken Moreland Relationship added related to 0003340
2007-08-15 18:00 Ken Moreland Assigned To => Clinton Stimpson
2007-08-15 18:00 Ken Moreland Status backlog => tabled
2007-08-20 13:57 Clinton Stimpson Status tabled => @80@
2007-08-20 13:57 Clinton Stimpson Resolution open => fixed
2007-08-20 13:57 Clinton Stimpson Note Added: 0008517
2007-08-21 12:12 Ken Moreland Status @80@ => closed
