0005515 | ParaView | (No Category) | public | 2007-08-15 21:42 | 2007-09-21 14:31 | ||||
Assigned To | Dave DeMarle | ||||||||
Priority | high | Severity | crash | Reproducibility | always | ||||
Summary | 0005515: CTH crashes when toggling down convert volume fraction | ||||||||
Description | I can get a consistent crash using ParaView 3.0.2, using CTH data. Crash is as follows: XP (Originally found using Linux) ParaView version 3.0.2 * Open file 3D_Flat/spcth.spcth (file is 292,234 bytes) * Turn on all cell data. * Apply. * Change from Outline to Surface. (Not sure if this step is necessary.) * De-select the "Down Convert Volume Fraction" button. * Apply. Crash. (Sometimes it doesn't crash, but I am not sure if this is user error or an inconsistent crash.) Before crash, # of cells is 27648 - as found in the Information tab. After crash, # of cells is 33800 - as found in the Information tab. Error is as follows: ERROR: In \alan\paraviewWork\src3.0.2\ParaView3\Vtk\Filtering\vtkDataSet.cxx, line 432 vtkRectilinearGrid (03FD8530): Cell array Temperature (eV) with 1 components, has only 27648 tuples but there are 33800 cells ERROR: In \alan\paraviewWork\src3.0.2\ParaView3\Vtk\Filtering\vtkExecutive.cxx, line 757 vtkCompositeDataPipeline (06933E50): Algorithm vtkPVGeometryFilter(04324B80) returned failure for request: vtkInformation (0696F878) Debug: Off Modified Time: 663038 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 KEYS_TO_COPY: UPDATE_BLOCKS FROM_OUTPUT_PORT: 0 | ||||||||
(0009183) Dave DeMarle (administrator) 2007-09-20 10:55 |
The reader was not removing the external ghost cells properly after the initial file open. Now it rememebers the real dimensions it computed initially (it already remembered that it had done it before, it just didn't use that knowledge sensibly) and reuses them. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkSpyPlotBlock.h,v <-- vtkSpyPlotBlock.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkSpyPlotBlock.cxx,v <-- vtkSpyPlotBlock.cxx new revision: 1.6; previous revision: 1.5 |
2007-08-15 21:42 | Alan Scott | New Issue | |
2007-08-29 15:57 | Berk Geveci | Status | backlog => tabled |
2007-08-29 15:57 | Berk Geveci | Assigned To | => Berk Geveci |
2007-08-29 15:57 | Berk Geveci | Priority | normal => high |
2007-08-29 15:57 | Berk Geveci | Category | => 3.2 |
2007-09-03 10:33 | Berk Geveci | Assigned To | Berk Geveci => Dave DeMarle |
2007-09-20 10:55 | Dave DeMarle | Note Added: 0009183 | |
2007-09-20 10:55 | Dave DeMarle | Status | tabled => @80@ |
2007-09-20 10:55 | Dave DeMarle | Resolution | open => fixed |
2007-09-21 14:31 | Alan Scott | Status | @80@ => closed |
