0005518 | ParaView | (No Category) | public | 2007-08-16 14:26 | 2007-09-11 19:38 | ||||
Reporter | David Thompson (old) | ||||||||
Summary | 0005518: SNL: Glyph filter doesn't provide reasonable "Scale Factor" when "Scale Mode" changed | ||||||||
Description | When the Scale Mode is changed from "vector" to "scalar" (or, I assume, "vector components"), the "Set Scale Factor" entry is not changed. While this is good because it's irritating to enter a scale factor only to have it overwritten when you change the scale mode, this also means that no reasonable default is provided when either the scale mode or the particular field used for scaling is altered. These reasonable values are hard to get without switching to the information tab of another filter. Perhaps a button to compute a reasonable scale factor should be provided to the right of the label entry? | ||||||||
(0008842) Utkarsh Ayachit (administrator) 2007-09-05 14:48 |
Scale factor is computed when scale mode (or scalar/vector selection) changes. That's the default behaviour, to explicitly set the scale factor use checks on the "Edit" checkbox and then sets the scale factor manually. /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.119; previous revision: 1.118 /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.cxx,v <-- pqGlyphPanel.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.h,v <-- pqGlyphPanel.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqObjectInspectorWidget.cxx,v <-- pqObjectInspectorWidget.cxx new revision: 1.52; previous revision: 1.51 |
2007-08-16 14:26 | David Thompson (old) | New Issue | |
2007-09-04 14:05 | Berk Geveci | Status | backlog => tabled |
2007-09-04 14:05 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-05 14:48 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-05 14:48 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-05 14:48 | Utkarsh Ayachit | Note Added: 0008842 | |
2007-09-11 19:38 | Alan Scott | Status | @80@ => closed |
