0005552 | ParaView | (No Category) | public | 2007-08-21 11:37 | 2007-08-28 12:21 | ||||
Assigned To | Eric Stanton | ||||||||
Summary | 0005552: Array leaked when reading Exodus metadata | ||||||||
Description | If you have compiled ParaView with VTK_DEBUG_LEAKS ON (and all us developers should), it reports that an array leaks when you load Exodus metadata. To see the problem, load disk_out_ref and turn on the Meta Data flag under the File Pattern group. After you accept and then exit ParaView, vtkDebugLeaks reports a vtkCharArray is still around. | ||||||||
(0008539) Ken Moreland (manager) 2007-08-21 11:40 |
I'm not sure what the Meta Data flag is really for. I assume it has to do with writing exodus files. I hope that sometime soon this flag can simply go away and all relevant metadata will be stored within the native VTK data structures. |
(0008553) Eric Stanton (reporter) 2007-08-21 14:04 |
Yea, the meta data flag is obsolete and I'll take it out of the exodus panel. |
(0008677) Eric Stanton (reporter) 2007-08-27 15:56 |
I'm not sure why this was happening because that checkbox shouldn't be controlling anything. Which is why I removed it from the panel. Once we update vtkModelMetadata to support multi-block, and the new edge and face data we can decide whether we need this checkbox or whether we can just pack the metadata onto the reader's output no matter what. |
2007-08-21 11:37 | Ken Moreland | New Issue | |
2007-08-21 11:37 | Ken Moreland | Status | backlog => tabled |
2007-08-21 11:37 | Ken Moreland | Assigned To | => Eric Stanton |
2007-08-21 11:40 | Ken Moreland | Note Added: 0008539 | |
2007-08-21 14:04 | Eric Stanton | Note Added: 0008553 | |
2007-08-27 15:56 | Eric Stanton | Status | tabled => @80@ |
2007-08-27 15:56 | Eric Stanton | Resolution | open => fixed |
2007-08-27 15:56 | Eric Stanton | Note Added: 0008677 | |
2007-08-28 12:21 | Ken Moreland | Status | @80@ => closed |
