0005556 | ParaView | (No Category) | public | 2007-08-21 16:21 | 2007-11-01 19:52 | ||||
Priority | urgent | Severity | minor | Reproducibility | always | ||||
Summary | 0005556: Save Animation of Plots | ||||||||
Description | When you save an animation with chart type views, the charts are not animated. Instead, they are stuck on the first time step. To replicate the problem, do the following. Load in can.ex2. Make sure at least the EQPS variable is loaded. Add the histogram filter and make a histogram of the EQPS variable. Hit the play button and you will see both the 3D view and the bar chart animate. Now go to File -> Save Animation. In the resulting animation, the 3D view will properly animate, but the bar char will be fixed at time 0. The same behavior happens for X-Y charts. You can show this by placing a plot over line filter on the exodus data. | ||||||||
(0008836) Utkarsh Ayachit (administrator) 2007-09-05 09:13 |
Plot view was not rendering prior to capturing the image. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotView.cxx,v <-- pqPlotView.cxx new revision: 1.13; previous revision: 1.12 |
(0009414) Ken Moreland (manager) 2007-10-10 15:38 |
This is broken again. When you save an animate containing a bar chart or x-y plot, the resulting images have empty plots in them. While the animation is being saved, you can see the chart updated in the GUI, so that part is working. However, when the image is saved to the file, the chart is totally empty. |
(0009480) Utkarsh Ayachit (administrator) 2007-10-15 13:18 |
In pqPlotView::captureImage(int), at the after forceRender() call, the plot view should have been updated to show the current state of the plot. However, if I add break point after that call, I notice that the plot view isn't updated. Also grabWidget doesn't seem to get the lines drawn on the plot, only the grid. Assigning to Mark. |
(0009515) Utkarsh Ayachit (administrator) 2007-10-18 13:57 |
Force processevents before plot view is captured since plots use Qt:QueuedConnection for updating the view. /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotView.cxx,v <-- pqPlotView.cxx new revision: 1.16; previous revision: 1.15 |
(0009606) Alan Scott (manager) 2007-11-01 19:52 |
Works client server. |
2007-08-21 16:21 | Ken Moreland | New Issue | |
2007-09-04 14:05 | Berk Geveci | Status | backlog => tabled |
2007-09-04 14:05 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-05 09:13 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-05 09:13 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-05 09:13 | Utkarsh Ayachit | Note Added: 0008836 | |
2007-09-11 17:44 | Alan Scott | Status | @80@ => closed |
2007-09-11 18:07 | Alan Scott | Status | closed => @80@ |
2007-09-17 18:11 | Alan Scott | Status | @80@ => closed |
2007-10-10 15:38 | Ken Moreland | Status | closed => @20@ |
2007-10-10 15:38 | Ken Moreland | Resolution | fixed => reopened |
2007-10-10 15:38 | Ken Moreland | Note Added: 0009414 | |
2007-10-15 13:15 | Utkarsh Ayachit | Status | @20@ => tabled |
2007-10-15 13:15 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Mark Richardson |
2007-10-15 13:18 | Utkarsh Ayachit | Note Added: 0009480 | |
2007-10-18 13:56 | Utkarsh Ayachit | Assigned To | Mark Richardson => Utkarsh Ayachit |
2007-10-18 13:57 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-10-18 13:57 | Utkarsh Ayachit | Resolution | reopened => fixed |
2007-10-18 13:57 | Utkarsh Ayachit | Note Added: 0009515 | |
2007-11-01 19:52 | Alan Scott | Status | @80@ => closed |
2007-11-01 19:52 | Alan Scott | Note Added: 0009606 | |
