0005561 | ParaView | (No Category) | public | 2007-08-22 14:12 | 2008-04-14 20:05 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005561: X Axis / Y Axis / Z Axis buttons not useful for Line source | ||||||||
Description | When you create a Line source, the [X|Y|Z] Axis buttons are not useful. They fill the point coordinate entry boxes with garbage values. This is happening because this widget needs an input dataset so it can use its bounds in setting the values from the [X|Y|Z] Axis buttons. These buttons should either be removed from the GUI for the Line source, or we should create default values for the widget to use when there is no input dataset. | ||||||||
(0008585) Amy Squillacote (reporter) 2007-08-22 16:10 |
Similarly, the "Center on Bounds" button has no effect for the Point Source, and so should probably be removed for that source. Like the * Axis buttons for the Line Source, it requires an input dataset in order to have any effect. |
(0011318) Alan Scott (manager) 2008-04-14 20:05 |
Works for me. Local. |
2007-08-22 14:12 | Amy Squillacote | New Issue | |
2007-08-22 16:10 | Amy Squillacote | Note Added: 0008585 | |
2007-08-29 16:06 | Berk Geveci | Assigned To | => Berk Geveci |
2007-08-29 16:06 | Berk Geveci | Status | backlog => tabled |
2008-04-14 17:15 | Berk Geveci | Status | tabled => @80@ |
2008-04-14 17:15 | Berk Geveci | Resolution | open => fixed |
2008-04-14 20:05 | Alan Scott | Status | @80@ => closed |
2008-04-14 20:05 | Alan Scott | Note Added: 0011318 | |
