0005565 | ParaView | (No Category) | public | 2007-08-23 16:59 | 2011-01-13 17:00 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005565: Selection is not shown when globa ids is check in selection inspector | ||||||||
Description | To reproduce: * load disk_out_ref.ex2 * select a cell * turn on "Use Global Ids" in the selection inspector * select cell(s) Nothing is shown. | ||||||||
Relationships | ||||||
(0008733) Berk Geveci (administrator) 2007-08-29 09:54 |
A few extra feature requests (I am sneaky): * Process id column should be shown in global id selection and in index selection when num procs = 1 * Tab should switch between fields making it easy to enter bunch of ids in a row * Switching between index and global id should convert selection values appropriately |
(0008762) Utkarsh Ayachit (administrator) 2007-08-29 16:06 |
Fixed part of BUG 0005565. vtkSelectionSource's state was dependent on sequence in which the different set/add methods (such as SetFrustum, AddID) we called with respect to SetContentType. Change content type would clear all previously added values. Also, SetFrustum, AddLocation etc all updated the same internal data structure based on the ContentType. Fixed it to be more VTK friendly. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/sources.xml,v <-- sources.xml new revision: 1.74; previous revision: 1.73 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.cxx,v <-- vtkSelectionSource.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkSelectionSource.h,v <-- vtkSelectionSource.h new revision: 1.9; previous revision: 1.8 |
(0008766) Utkarsh Ayachit (administrator) 2007-08-29 16:46 |
Now process id is shown only when the connection has more than 1 processes. Also, we are now using the same widget for global ids and indices since we are linking with the same servermanager property. /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.207; previous revision: 1.206 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- pqSelectionInspectorPanel.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.h,v <-- pqSelectionInspectorPanel.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSelectionInspectorPanel.ui,v <-- pqSelectionInspectorPanel.ui new revision: 1.6; previous revision: 1.5 |
(0008899) Utkarsh Ayachit (administrator) 2007-09-10 09:15 |
* vtkSelection::Union combines selection lists only if the two selections are have identical "properties". Otherwise, it creates a composite selection. * vtkAppendSelection no longer needs to support the "append by compositing" mode since vtkSelection::Union does not merge selection lists unless all properties are identical. * When uses checks (unchecks) the "Use Global IDs" check box, we not convert the current list of indices to global ids (or vice versa). * Added new vtkPConvertSelection filter that respects the process id. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- pqSelectionInspectorPanel.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.h,v <-- pqSelectionInspectorPanel.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.cxx,v <-- pqSelectionManager.cxx new revision: 1.57; previous revision: 1.56 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.h,v <-- pqSelectionManager.h new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.154; previous revision: 1.153 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPConvertSelection.cxx,v <-- vtkPConvertSelection.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPConvertSelection.h,v <-- vtkPConvertSelection.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- filters.xml new revision: 1.260; previous revision: 1.259 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- rendering.xml new revision: 1.249; previous revision: 1.248 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkSelection.cxx,v <-- vtkSelection.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkSelection.h,v <-- vtkSelection.h new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkAppendSelection.cxx,v <-- vtkAppendSelection.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkAppendSelection.h,v <-- vtkAppendSelection.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/VTK/Graphics/Testing/Cxx/TestAppendSelection.cxx,v <-- TestAppendSelection.cxx new revision: 1.4; previous revision: 1.3 |
(0009113) Utkarsh Ayachit (administrator) 2007-09-19 09:25 |
Creating a new bug 0005749 to capture the interaction issue with the selection inspector. |
2007-08-23 16:59 | Berk Geveci | New Issue | |
2007-08-23 16:59 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-08-23 16:59 | Berk Geveci | Status | backlog => tabled |
2007-08-29 09:54 | Berk Geveci | Note Added: 0008733 | |
2007-08-29 16:06 | Utkarsh Ayachit | Note Added: 0008762 | |
2007-08-29 16:46 | Utkarsh Ayachit | Note Added: 0008766 | |
2007-08-31 11:44 | Utkarsh Ayachit | Relationship added | related to 0005239 |
2007-09-10 09:15 | Utkarsh Ayachit | Note Added: 0008899 | |
2007-09-19 09:25 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-19 09:25 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-19 09:25 | Utkarsh Ayachit | Note Added: 0009113 | |
2007-09-25 20:05 | Alan Scott | Status | @80@ => closed |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
