0005575 | ParaView | (No Category) | public | 2007-08-26 23:32 | 2009-12-10 20:26 | ||||
Reporter | pvc | ||||||||
Assigned To | |||||||||
Summary | 0005575: Probe does not read correctly datas | ||||||||
Description | Hi, I suspect a bug but I may be wrong... Actually, when plotting the datas through the Probe function, I have for Uz a range a value that is [0:0] though in "ExtractPart" it is [-0.656207;0.656207] I attached pixies.. Regards | ||||||||
Attached Files | BugParaview_withProbe.pdf [^] (313,594 bytes) 2007-08-26 23:32 | ||||||||
(0018808) Berk Geveci (administrator) 2009-12-10 20:26 |
Depending on where the probe lies, it is possible to get a [0, 0] range out of probe. If you disagree, please provide data and steps to reproduce. Thanks. |
2007-08-26 23:32 | pvc | New Issue | |
2007-08-26 23:32 | pvc | File Added: BugParaview_withProbe.pdf | |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
2009-12-10 20:26 | Berk Geveci | Note Added: 0018808 | |
2009-12-10 20:26 | Berk Geveci | Status | backlog => closed |
2009-12-10 20:26 | Berk Geveci | Resolution | open => no change required |
