0005578 | ParaView | (No Category) | public | 2007-08-27 15:39 | 2007-08-30 16:01 | ||||
Reporter | Clinton Stimpson | ||||||||
Priority | high | Severity | crash | Reproducibility | always | ||||
Summary | 0005578: crash starting up after changing view settings in the last session | ||||||||
Description | In my last session, I had changed my LOD threshold. Then ParaView wouldn't start up anymore, with this output $ bin/paraview Failed to create a proxy for the requested view type. Segmentation fault I finally traced this down to a defaultViewType in QSettings. By default, when the application settings dialog is opened, it is set to None, and ParaView crashes at startup if it is None. | ||||||||
(0008700) Utkarsh Ayachit (administrator) 2007-08-28 09:00 |
Fixed crash when view type is set to default. Also fixed the dialog to not change the default view type to None when the dialog is opened the first time. /cvsroot/ParaView3/ParaView3/Qt/Components/pqApplicationSettingsWidget.cxx,v <-- pqApplicationSettingsWidget.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/pqMainWindowCore.cxx,v <-- pqMainWindowCore.cxx new revision: 1.206; previous revision: 1.205 |
2007-08-27 15:39 | Clinton Stimpson | New Issue | |
2007-08-27 15:44 | Clinton Stimpson | Status | backlog => tabled |
2007-08-27 15:44 | Clinton Stimpson | Assigned To | => Utkarsh Ayachit |
2007-08-28 09:00 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-28 09:00 | Utkarsh Ayachit | Resolution | open => fixed |
2007-08-28 09:00 | Utkarsh Ayachit | Note Added: 0008700 | |
2007-08-30 16:01 | Ken Moreland | Status | @80@ => closed |
